K2e2vin
hey guys, im trying to run a D16A1 transmission(88-89 integra) but i read it doesnt fit other d-series engines. I also want to run a clutch/flywheel meant for the EGs(because noone makes anything for 88s).
here's what im thinking and reasoning:
Stock 88 CRX DX Case: Cable clutch, i already have it so i guess its considered "free"
93 CX Main and Counter shafts; 20 spline shaft
Aftermarket(Fidanza maybe) Flywheel; the ones they make only fit 90-2000 SOHCs i think.
D16A1 gearset
1. would it be possible to put the 93 CX transmission main shaft in there?
2. is it possible to put the D16A1 gears on the CX shaft?
3. any other problems that will be encountered?
Thanks, Kevin.
D16A1 gearset
Thanks, Kevin.
