super high idle
vdubber
Member
i just put a used but working eacv from my friends d16a6 motor onto my b16a. the problem now though is that before it wold idle at 1.5k and had a dead spot at 3ks. now my engine when i turn it over it doesnt idle at all. The engine just starts pulling to redline really fast. wtf is happening? and yes my plug is hooked up.
Try adjustin your throttle. Theres a screw thing on the tb. Just play around with it to see where you want to idle. I tried emailing you back but it didn't go through.
it doesnt matter how i adjust the screw, my motor all of a sudden just starts pullin for redline no matter what eavc i use i am so confused?
Then try adjusting your throttle cable? Are you still throwing codes? My bro was messing around with the throttle cable and when he did it too tight it redlined quickly.
