suspension bushings
Discussion in 'Wheels / Suspension / Tires / Brakes' started by bcman, Jan 8, 2004.
  1. bcman
    bcman Senior Member
    Davis, CA
    Well, the corners of my car are getting all squeaky, and steering precision is getting a little blurry. so it's time for new bushings. Any recommendations? what's better, rubber or poly?
  2. sportlinecrx
    sportlinecrx Banned
    Energy Suspension bushings. they are the best. all aftermarket bushings are polyurethane. only OEM are rubber...theres no good reason to get OEM again. the price of OEM from the dealer would probably cost more than a good aftermarket set like Energy.
  3. Jazzy19
    Jazzy19 Senior Member
    which bushings are you changing
  4. phunky.buddha
    Dallas / Fort Worth, TX
    ES = not necessarily the best, but they're pretty damn good and available everywhere. I'm running a set in my car.
  5. radnulb
    radnulb Senior Member
    Sinsinnaty, Ohio
    ES bushings won't necessarily get rid of noise either... If you don't grease them JUST right, they have a tendency to creak, especially on cars with a lot of chassis flex. A friend's del sol sounds almost scary going around sharp right hand turns but it handles flawlessly. CREAK. Poly bushings make the car a lot louder overall I think... More road noise gets transmitted to the frame. It's night and day vs old stock rubber bushings in terms of handling.
    What is best for you depends on what you want to get out of your car. Poly last longer and have better performance characteristics, rubber is more forgiving, quiet and gentle.
  6. mjfubar
    mjfubar Member
    CALI
    yea my friend has a set of poly engine mounts and they make his car sound like a tank inside and the car is hella quiet outside so just depends on what you can put up with. i want to put the ES bushing all around my civic does anyone have an opinion on how they help or hurt.
  7. bcman
    bcman Senior Member
    Davis, CA
    Thanks for the responses, guys. I took the car in to a mechanic yesterday and he said that the rear trailing arm bushings are shot (the really large bushings). I'll probably replace all bushings with ES some time in the future, but the trailing arm bushings really need to be fixed soon. Does anyone know if ES makes poly bushings for the trailing arms, or do they just make the smaller bushings?
  8. red95solsi
    red95solsi Senior Member
    Kansas City Missouri
    spoon makes slightly stiffer rubber bushings but they arent as stiff as energy suspension
  9. phunky.buddha
    Yup, they make a separate trailing arm bushing kit. I think that the master kit for the Civic actually does NOT include the trailing arm bushings, so go ahead and do yours now. You won't be buying duplicates if/when you do the master kit. Just those two bushings will make a MAJOR difference in how your car feels, trust me.
  10. sportlinecrx
    sportlinecrx Banned
    ok so Energy is not the best. my bad :) still very good though. can't go wrong with them.
  11. StyleTEG
    StyleTEG Senior Member
    Stay away from the ES trailing arm bushings. (the rest seem to be pretty good).
    Those perticular bushings don't allow enough deflection and movement, as the TR requires. The result is binding, which is of cource, not good.
    The mugen is a good alternative. It is stiffer than stock, but not so stiff that it hinders the motion required.
  12. B16
    B16 Super Moderator VIP
    yay area, CA
    i would use the mugen trailing arm bushings and poly everywhere else. i see alot of the honda challeng guys doing this to keep the geometry of the rear suspension, i guess the poly is too stiff for proper movement back there.
    EDIT:
    haha, i just read the post above me, so uh, ya, what he said.
  13. phunky.buddha
    Hmm. I haven't noticed any binding... but if I run into it, I'll take it all apart and throw in another set.
  14. bcman
    bcman Senior Member
    Davis, CA
    Too late! I already bought a set of ES trailing arm bushings. I'll let you know what they're like once I get them installed.
  15. bcman
    bcman Senior Member
    Davis, CA
    Hey calesta, how did you get the metal spindle out of the OEM bushings? My ES kit only comes with the polyurethane, but no spindles. I'm considering machining new spindles, any advice?
  16. bcman
    bcman Senior Member
    Davis, CA
    Anybody else have suggestions? should I machine new spindles, or just scrape all the rubber off the OEM spindles?
  17. phunky.buddha
    You use the stock spindles (if that's what they're called)- just burn or grind the old bushing material off the spindle, then install the bushing and old spindle.
  18. bcman
    bcman Senior Member
    Davis, CA
    What's the best way to get the rubber off the metal sleeve that stays in the trailing arm? It's nearly impossible to cut it out, because of two crescent-shaped pieces of metal within the sleeve. I'd burn it out, but I'm worried about the fumes and annealing the metal sleeve. What would you recommend?
  19. racintweek
    racintweek Senior Member
    Arlington VA
    remeber not to flip the spindles around they need to go bak in exactly the way they came out
  20. UDT
    UDT Senior Member
    california
    im not sure how much rubbers there. But i say take it out back put some vice grips on it and grap a lil hand torch. ;)
