Suspension conversion
Discussion in 'Wheels / Suspension / Tires / Brakes' started by YangpaNemsay, Nov 12, 2002.
  1. YangpaNemsay
    YangpaNemsay Senior Member
    Okinawa, Japan
    Would it be better to switch out the front strut and torsion beam (front), and solid rear axle (rear) suspension with Double Wishbones? I heard that the first gen integs are zippy due to the solid rear axle, but newer suspensions also have their technological advantages. WHaT SHouLD i Do?!?!?!
  2. pissedoffsol
    sell the car if you want to go fast.
    sorry dude... but its jsut reall y hard to work on and nothign fits or goes right in without some work...
  3. phunky.buddha
    Dallas / Fort Worth, TX
    Ouch. Good luck swapping all those parts out. I doubt that the mounts are even there for the wishbone setup... you'd be in for some cutting and welding!
  4. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Get a Gen 2 Integra, they don't cost much, they have a double wishbone suspension, any B series engine fits right in, and there is sooooo much more aftermarket support for it than the gen 1.
