There's a cheap way to remove the stock springs without a spring compression as long as you're installing drop springs in their place. I haven't had to use a spring compressor in a while.
Care to elaborate?
When the strut/spring is removed as an assembly, you need a spring compressor to relieve the pressure on the spring when removing it from the strut. Some people try to be heroes and remove it by hand. This is VERY dangerous.
He pretty much released the bolts holding the spring down with it inbetween his legs. When the tension was released, it overcame his own strength and shot upwards, clipping his chin and tearing skin off his chin from the bone, up to his bottom lip. Pretty nasty stuff right there. Had pictures on an old cell years ago. No longer have em. Im sure you can google for pics of that mess happening to other people. Might even be a video on youtube.
