suspension opinions (don't flame me)
Discussion in 'Wheels / Suspension / Tires / Brakes' started by red91efhatch, Feb 12, 2009.
  1. red91efhatch
    red91efhatch New Member
    Albuquerque
    Ok so I know the name of that game is read, search, read then search again and I have. I've reviewed several suspension threads and there are so many options Tein, Megan, H&R, Tokico, Koni, etc etc etc. I thought I was set on getting this Tokico setup Jazzproparts, Your one stop performance and JDM Solution.
    But after reading all the posts I have yet to see one recommendation for this setup. Now for my info
    Budget: $1000 with shipping etc.
    Use auto x 5-7 times a year
    I don't how "dropped" the car is I'm looking to have a 17 year old car with Z06-350z (you get the picture) handling no "cholo bounce" and would like adjustable dampening etc.
    I have taken note on koni yellow/GC springs, Megan coilover, H&R coilover and on and on, I realize some come in over 1,000 so I may be willing to go a little bit over. Are Tein coilovers worth $1,300+? the EFDC seem convenient but ???
    If anything I will settle for the illuminas as I have rode in several vehicles and would be satisfied running Illuminas. any spring combo recommendations are welcome for just the illuminas
    thanks,
    Rob
  2. Bkkfarang
    Bkkfarang New Member
    Bangkok and Shenzhen
    Ok to be fair I am not flamming you ,but the short answer an EF will never handle like a zo6 or a 350z (FF vs FR)
    to come even close you will need more than springs and shocks , bushing , sway bars , camber kit, good tires , ect . and that will easily set you over 1000 .
    the Tokico setup is good basic upgrade quality parts
  3. Bkkfarang
    secondly the best way to get Flamed is to say Don't flame me
  4. red91efhatch
    Albuquerque
    Fair enough flame me I probably deserve it :mrgreen:, the 1k is for coilovers alone I will be adding other supporting mods listed above. my suspension budget is around 2.5k altogether but I want to keep costs low and concentrate on one component at a time.
  5. eg6sir
    i say Koni Yellows w/ Ground Control coilovers..
  6. CRX-YEM
    Wallingford, CT
    imho, kyb agx's with neuspeed sport springs, overall 1.7-1.8" lower. 4 pos. adjustable dampening. Should come in at about $700-800.
  7. Briansol
    what tires do you use for autox events?
    what class are you in/want to be in?
    how are your courses set up? (tight, long straights, little bit of everything, etc)
  8. autox 89 dx
    autox 89 dx Member
    SF bay area
    If you want your car to handle good in autocross you shold go with the Konis and ground controll set up. Then get some sway bars then a camber kit then find some one that can corner balance your car to dail it all in.The only thing is that is more than $1000 bucks.
  9. E_SolSi
    if you are not going to corner balance the car then there is no real point in getting adjustable coilovers... just get springs
  10. eg6sir
  11. eg6sir
  12. red91efhatch
    Albuquerque
    Thanks for the responses, the car will be corner balanced, we have local auto X events and SCCA events here, I'll likely be in super modified class due to the swap but my goal is only to have fun maybe one day ill get serious about it and start off in stock-g or something.
  13. MthaFuknGreen
    Lodi, CA
  14. eg6sir
    umm ok.. enough post whoring green
  15. whyamionahondaforum
    whyamionahondaforum New Member
    how does a company like eibach compare to the koni's or KYB's?
  16. eg6sir
    one makes springs/coilovers, the other makes shocks.. thats how they compare..
  17. whyamionahondaforum
    I know, but like a full coilover sut up in eibach, how would that compare to koni yellows with a quality spring?
  18. eg6sir
    the Koni/GC combo has been track proven.. not sure on the Eibachs
    1 person likes this.
  19. red91efhatch
    Albuquerque
    Again thanks for the flames and replies, I'm going with the koni/gc combo went to the GC site, it's stating their springs are mfg. by Eibach? sound right?
    Also I'm looking at purchasing from the gc web site, they're asking for spring rates, anyone know where I can get some good info./knowledge to calculate the spring rate I should need?
  20. autox 89 dx
    autox 89 dx Member
    SF bay area
    That sound right, and for the spring rate you should probably go with 450F/550R
