Suspension Upgrade...
acurabdby
Member
;) Hey guys quick question I'm thinking of redoing my suspension i currently have nuespeed springs with stock shocks and struts its pretty low and i keep bottoming out i wanted to upgrade to coilovers...my ideal set up is Koni Adjustables all around w/Groundcontrol Coil overs. What do u guys think of it? I know its a bit pricey but i'm willing to spend a lil extra and get good handleing and not damage my DC sports header anymore!!
That is a nice set up however, for the amount your spending for like $50 more, you can have yourself a set of Tein SS's which are true coilovers (true coilovers >>>>>>> sleves)
On group buy you can find them for about 850 and I have seen them as low as 825 on honda tech.
Originally posted by acurabdby@May 14 2003, 07:03 PM
...Koni Adjustables all around w/Groundcontrol Coil overs. What do u guys think of it?
:worthy: that would be my ideal setup too. B) BTW, a set of ground control coilovers only run about $300+.
Thats great info however the TEIN SS coilovers run about $1k and like was mentioned before the Ground Control are only about $300 or so, but both would work just fine , thanks for the info. :D
the ground controls dont come with dampeners
so add that to the $300 pricetag
koni yellows are about $500
so now your at $800
a set of true coilovers will only cost about $25-50 more
True guys I realized now that it includes the dampners and on top of that theres alos those electronic dampner controlers that are also cool to have so I may be going the TEIN way!! :huh:
a set of tien coilovers WITH dampers for less than $1000????!!!!!! i find that very hard to beleive.
the dampers are part of the tein coilovers, you cannot get them seperate.
$850-$900 a set, pillow mounts are NOT included though, but you can use stock ones.
950 for Tein SS is crazy. If you look around you can get them for almost a hunderd cheaper
no, 750 shipped from some dude in Va. would be HA prices :) Go on hondatech, there are always deals here and there
