Suspension?
Discussion in 'Wheels / Suspension / Tires / Brakes' started by evans, Apr 28, 2008.
  1. evans
    evans 91 Civic Project
    Saskatchewan, Canada
    hey guys, I want opionions on the type of suspension I should get..
    I have all new poly bushings in the arms after i sand blasted them and painted them.. now I want to know what kind of coilovers I should have.
    Car-- 91 Civic HB with future H22.
    Now opinions? Price is no object.
  2. t3t4delsol
    t3t4delsol New Member
    York, Pa
    if you plainning on putting a h22 in I would look for some really heavy springs for up front, I dont think the coilovers would hold the abuse of that heavy motor
  3. Steovts
    Steovts Irish Member
    Ireland
    I have Tein Superstreet suspension on my H22 EF Civic and they are ment to be good.Just get good suspension as you will need it
  4. E_SolSi
    i believe Ground Control makes a set of coils specifically for civics with H22 swaps
  5. evans
    well i dont think it will need to be that much stiffer.. I mean the H series is not that much heavier than a B series..
  6. BrutalB83
    Rochester Hills, MI
    Progress does too...
  7. LSCRX
    LSCRX New Member
    The H22 is not that much heavier than the bseries motors. I think the H22 is too heavy to swap it just a myth or rumor. Sure it weights more its a bigger motor, but not much more. You should be able to run any normal coilovers for the swap. I would go with buddyclub....
  8. t3t4delsol
    York, Pa
    the h22 will sit farther towards the front of the car, thous creating under-steer, also throwing off the weight distribution, this doesn't occur in b-series swaps, this is why the h22 is heavier and stronger springs are required
  9. E_SolSi
    :concur:
    but feel free to waste money finding out we were right
