Suspension
Discussion in 'Wheels / Suspension / Tires / Brakes' started by SIRH22, Feb 7, 2003.
  1. SIRH22
    SIRH22 Member
    Harlingen Texas, Close to South Padre Island
    Does anybody notice rattling from their rear suspension? I have sportlines with KYB GR-2s in the rear.
  2. texan
    texan Junior Member
    Check your upper shock mounts for proper torque, this is the most common cause of suspension rattle/knock.
  3. pissedoffsol
    you sure its not just your car?
  4. phunky.buddha
    Dallas / Fort Worth, TX
    Improper spring installation? Make sure the springs are seated correctly- that's the most common cause.
  5. ALLJDM
    ALLJDM Senior Member
    Tampa, FLorida
    I do get a small rattle when I go over a bump. But I do believe that I know what it came from. YOu should check some of your bolts and seats just to make sure that it was done properly.
    GOOD LUCK
  6. SIRH22
    SIRH22 Member
    Man i checked everything and its all in place and very tight. The rattle is not that loud, its just a light rattle. I think its the spring rattling. :huh:
  7. E_SolSi
    :withstupid:
    is it a hatchback?? if it is try lubricating the seals... that could be the chattering your hearing
