brian11to1
There are a few problems...
1. Theres an exhuast leak - where the downpipe connects to the cat/b pipe... no big deal...
2. It over heats - I think the thermostat is sticking and hte heater core hoses are leaking... again no big deal...
3. Runs rather rough - Surges I'll but I can check some shit...
4. Code 17, Vehicle Speed Sensor... I didnt hook it up
5. It wont go into Gear. With the clutch pedal all the way to the floor the gear selector will not allow the selection of 1st-5th nor Reverse. Reverse just grinds. I shimmed the mount as instructed. Im using an Exedy Clutch and Kaiten Flywheel... Would there be any problems with this setup. Should I swap back to the stock flywheel?
Please help.
Please help.
