Swap B18A1 into 91 CRX Si
Discussion in 'Civic and CRX - EF' started by CrixSi91, Jul 9, 2006.
  1. CrixSi91
    CrixSi91 Junior Member
    Port Deposit, MD
    I need help with a Swap!!!!! B18A1 into 91 CRX Si
    I have a stock 91 crx. when I bought it, a b18a1 came with it. it was never installed. i have bought the motor mounts and a trans. i know i need a fly wheel and clutch assembly. Now i need help. what else am i going to need? And were would be a good place to find these items?
    thanks i need as much info i can get.
  2. redef91
    redef91 Senior Member
    Boston,Ma
    search ebay u'll find everything u need
  3. Taco15
    Tallahassee Fl
    you have the axles? I hope you have at least an ls ecue to run it. ohh and make sure its obd0.
  4. CrixSi91
    Port Deposit, MD
    i have the ecu but which axles do i need?
  5. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    Basically this is your list of things to complete the swap.
    Engine
    mounts
    Trans
    Axles (90-93 integra to answer your Q)
    shift linkage
    ECU
    wiring (knock sensor..... I think thats it.. or is it only the b16's that have the knock??? I forget. sorry.)
    Thats what you need.
  6. CrixSi91
    Port Deposit, MD
    the acura axles will fit inside the stock crx si hubs?
  7. Andrew
    Tallahassee, FL
    Yes the DA integra's have the same spline count and fit right in there with no problems.
    All B-series swaps in EF's use these axles.
    Edit- need to learn to spell...
  8. phyregod
    phyregod !!YTINASNI
    Central Texas
    Actually, they dont exactly fit, you have to pull out some metal dust rings from inside of the spindal. Then they fit like a champ. And no additional wiring will be needed with a b18a1 in a CRX Si. Just plug in the Acura ECU, plug in the motor, and smile.
    I did exactly the same swap in my crx si.. was pretty painless, and fun when I was finished.
  9. ispool2
    ispool2 Junior Member
    DO SOME REASERCH! everyone wants every thing handed to them. Go to Hassport.com and they have a list!:eek::eek::eek::eek::eek::eek:
  10. Andrew
    Tallahassee, FL
    Take it easy pacha...
    We, at least the most of us, don't mind helping people out, thats what this site is all about.
    However you are correct in saying some should search more. Also people should call Hasport and just talk to them about any questions/concerns you have. Thats what there Technical Staff is there for. Take advantage of it!
    4 posts and your already a moderator?
    haha..
  11. reikoshea
    Dallas, TX
    .......dont be takin my job buddy.
  12. ajisdope
    ajisdope Junior Member
    Sorry to hijack, I have been working on a B18B swap into my '90 crx HF and the only thing I have been worried about is the wiring. I have a PR4 ecu to run it. Is it plug and play? :confused: Thanks for any help...
  13. reikoshea
    Dallas, TX
    that ecu should be plug and play if you convert the engine to obd0
    in the future, make a new thread.
  14. ajisdope
    Thanks...sorry for the hijack. :)
  15. Andrew
    Tallahassee, FL
    :p
