swap complete problem
Discussion in 'Civic and del Sol - EG and EK' started by zap45, Jul 13, 2008.
  1. zap45
    zap45 New Member
    albuquerque nm
    ok started the f22b today but only one cylinder is firing. We forgot the map sensor. my question is that would a map sensor cause the engine to run off of one cylinder, also it has irregular idle too. The engine cant stay running either it just goes dead. Maybe could be the fuel injectors are bad. any suggestions? thanks.:mad:
  2. sam_iam
    sam_iam New Member
    have you done a compression test?
    who did you buy your motor from?
  3. zap45
    zap45 New Member
    albuquerque nm
    let me explain better we forgot the map sensor but without it will it cause one cylinder to only work, irregular idle, or dont i just got some bad fuel injectors
  4. zap45
    zap45 New Member
    albuquerque nm
    tigerjapanese.com no i have not done a compression test
  5. efhondakid
    Akron-Canton, Ohio
    Check your comp, then spark to the other three, then fuel.
  6. zap45
    zap45 New Member
    albuquerque nm
    well we forgot about the map sensor would this cause the other three sensors to not fire or would it be the bad fuel injectors
  7. zap45
    zap45 New Member
    albuquerque nm
    well we forgot about the map sensor hooking up the map sensor would this cause the other three cylinders not fire or would it be the bad fuel injectors?
  8. efhondakid
    Akron-Canton, Ohio
    To check to see if your injectors are working, take a screwdriver, start the car, put the business end on the injector and your ear to the handle, you should be able to hear it ticking.
  9. zap45
    zap45 New Member
    albuquerque nm
    ok we are gonna try all these solutions plus getting and hooking up a map sensor
    thanks. i will keep u posted
  10. mintoxik
    mintoxik Member
    Oceanside
    thats freakin sweet
    aka old schooler hahaha
  11. zap45
    zap45 New Member
    albuquerque nm
    well the compression is excellent 160.0 165.0 160.0 160.0
    next we will hookup the map sensor and check if the injectors are bad or not:)
  12. zap45
    zap45 New Member
    albuquerque nm
    well the fuel injectors were bad and all cylinders fired up we are almost done
    thanks for ur suggestions guys:)
  13. prpprimo
    prpprimo Hondaholic
    ABQ
    that is crazy..Ive never heard of 3 injectors going bad at the same time. Yes the map sensor helps control fuel and air delivery depending on manifold pressure. Most all the sensors do for that matter.
    MAP = manifold air pressure
  14. lsteggy
    lsteggy New Member
    ct
    hmmm maybe this is why my car runs like crap too?? i too bought my b18b from tigerjapanese and my valve seals are shot, maybe my injectors are bad,
