Swap Help...........please!
Discussion in 'HYBRID -> EG-EK / DC' started by Dathan81, Mar 28, 2003.
  1. Dathan81
    Dathan81 Junior Member
    I just finished swapping a USDM b16a2 into my 96 ex coupe i used my stock wiring harness with a ecu adapter from hasport, heres my problem, everything is in place and connected but my car wont start. when i try to start it it will click once a similar click to the one when the starter is dead but i tested the starter and it works fine...........did i do something wrong?? do i need to add or remove wires? is this a common problem?
    someone please help
    Dathan
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Are you sure you have everything plugged in properly? It sounds like you are missing a wire to the starter.
