swap help!!!!
ok i just finished a motor swap a mpfi engine into my 90 civic hatch(dpfi). but it has a power lack? and wondering why? maybe bc the egr sys is not hooked up? it is also poping up the ecu code 9( cylinder sensor) and 12 egr lift would these codes make the car run weak. could another possible cause be the throttle cable? thanks for any info
if you are throwing codes them your motor is going into limp home mode... or the ecu actually switches to limp home mode...
and takes all power and performance from your motor to attempt to save it from breaking more... or destroying it cause something is throwing codes
what do you mean ONLY???????
ANY = fuxored...
and i know for a fact that something wrong with the egr will affect EVERYTHING about your performance
ANY = fuxored...
:withstupid:
