swap help
adanej1
iam goin to start on my swap i have a b16a obd0 im an puting it into a civic 95 iam goin to be using my single cam engine harness is there anything i need to change? i already changed the alternator, im using an obd1 intake manifold, and the distrubuter, anything else i need to change? the harness is wired for vtec already
Sounds like you have it under control. I can't think of anything that would cause problems right now...maybe something will come to me later, but as of right now you're good to go.
Intake is complete OBD1? (like injectors?)
Knock Sensor to D3 if you are using a virgin ECU (also needs to be OBD1)
I have a JDM P30 if you are in need.
B16 have all the mounts? If not...you at least need the T-Bracket trans mount.
yea the manifold is complete... and im also using the p30 ecu... so i tried puting in the motor just now but the t braket i got ddnt line up corectly it was to close to the fire wall. im not so sure wat the t braket i got came out of..... i think i need a 94 integras. am i corect?
94-01 Integra T bracket. Or 94-97 del sol VTEC or 99/00 Civic Si
And you will need to run the knock sensor if you plan on running a virgin P30
