Hi swapping an A6 block with an d16y8 head and a 96 ecu, into a 2000 si. its all hooked up but when i use the 96ecu it wont turn on the fuel pump. I'm using the original harness from the car, but the injector plugs didn't fit so i swapped the intake with the original. Cant seem to get to run. also the distributer id from the A6 block. any help would be great.
