swap help
rex187
i cant get to the rear motor mount on my 91 crx. do i hve to drop the cross member or go at it with at wrench? if some one could tell me how to get to it.
I had that same problem, I did a small write up last summer on it, try searching for it. It explains exactly what I did to get it off.
And no, you don't have to drop the crossmember, just need a bunch of 1/4" sockets.
IT FITS IN ITS JUST A BITCH. I COULDN'T GET A TORQUE WRENCH ON IT THOUGH. JUST KEEP THE OTHER TWO MOUNTS LOOSE AND MOVE THE ENGINE AROUND UNTIL THE MOUNT FALL INTO PLACE.
If your doing an auto to manual swap, you have to move it to get the rear transmission mount on. Unless you have or can make some fancy adapter.
i got it off. i went along the fire walll and was able to get it with no probs
