swap help
Discussion in 'HYBRID -> ED-EF / DA' started by BLOWBYUREX, Aug 2, 2005.
  1. BLOWBYUREX
    BLOWBYUREX Member
    were swapping a b18A into a crx, wondering can we use the d seies crank pulley on the b-block, so i can use the d-alternator on the B engine, cause the d-pulley does not have a/c and p/s, anybody know if it would work
  2. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    :no:
    Not exactly sure what your asking, hope that this helps.
    If u don't use a/c or p/s just leave it, only run the belt for the alternator, it clears fine. That's what I have in my b16 crx.
  3. BLOWBYUREX
    BLOWBYUREX Member
    To make it simpler can i use my d series alternator on the b-motor without swapping crank pulleys
  4. ripperbone
    ripperbone angry bear
    Oklahoma
  5. 90sihatch
    90sihatch Senior Member
    you just gotta beat the fender well a little for clearance
