I'm just starting to build up a 91 CRX HF and have a question about doing it in stages. I would like to start with suspension/tire work first then move into an engine swap (B16), then possible into cosmetic... so basically handling, performance, bling-bling.
As I understand it, when I do the engine swap I need to replace the axles/hubs with a set from an Integra... if I buy new wheels now, will they fit the Integra hubs when I do the swap?
Thanks... Hey, its a learning process right :unsure:
