Swap legit?
HondaManMD
Ok i have a 93 d16z6 and want to put it in a 94 ex coupe... Will the swap pass inspection?
It is the same motor... exceot for year. And pending on what stae you live in depends on the criteria for inspection. Im 100% sure it will pass.
:werd:
Although it may be illegal, there is no way the insp. people will be able to tell your 94 car has a 93 motor in it unless they check the VIN tag on the motor.
You should be fine . . .its not like your car gets 0bd2 tested . . . :ph34r:
