Swap Problems
Discussion in 'Integra' started by gen2integ, May 21, 2008.
  1. gen2integ
    gen2integ Project started
    hi there i have a 1990 integra gs that started as an automatic i have swapped the motor and transmision out of the car for the motor and trans from a 1993 integra rs 5 speed manual. the swap worked out fine the new motor and trans are in and hooked back up the problem that i am having is that when i start up the car it revs up and idles between 2500 and 3500 rpm. i have replaced the throttle body gasket and checked the vaccum lines and im considering replacing the vaccum lines. if anyone has any ideas of other things that may be causing this problem that would be greatly appreciated
  2. Justin66
    Justin66 The Hondaswap Canadian
    Peterborough, Ontario
    idle adjustment?
  3. integraslut78
    integraslut78 Stylus DJ Extraordinaire
    KiLLa kALi
    hmmm wow that's high, check your TPS and idle screw and crank that bitch down.
