Swap Question
Discussion in 'HYBRID -> EG-EK / DC' started by crx-si, Jan 21, 2003.
  1. crx-si
    crx-si Member
    O.K. guys i am doing a b18a swap into a 89 crx si and i think i have all the parts i need motor, tranny, ecu, side axles, throttle cable, and mounts.
    any thing else that i need, and the wiring, any changes that i should know
    about any help on this would be appreciated as this is my first swap
    Thanks guys.
  2. SleEPeR_CRX
    SleEPeR_CRX Senior Member
    Vancouver B.C. canada
    Hasport pretty much sums it up, make a dent on left frame rail, blah blbah blah, its all on there man. not that much to screw up, LS is a easy swap as swaps go. Goodluck and enjoy:)
  3. crx-si
    crx-si Member
    Do the two harnesses plug together or do i have to change anything.
  4. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    just take the wiring off the motor and use your harness off the crx.
