michael_antoi
Member
dual carb (d15z2) to d15b vtec swap
first question - where does this plug go. I think i removed it when i was attaching a few hoses now i cant find where it goes.
This is the drivers side of the engine bay. (above)
Next question. The thermostat wiring has this third brown wire that connects to nothing. Where is this spose to go? there are 2 wires going to the ground (as seen in pic) so it cant be part of the ground. Thermostat wires look intact. What could this be?
COuld this be the reason my main relay is buzzing when i turn the key? I wired in a main relay because my carb didnt have a relay to power my fuel pump etc...now when i turn the key it buzzes...
http://www.ozhonda.com/gallery/watermark.p...719IMG_0231.jpg
http://www.ozhonda.com/gallery/watermark.p...719IMG_0236.jpg
HERE ARE THE IMAGES
HERE ARE THE IMAGES
