Swap ?
Discussion in 'HYBRID -> EG-EK / DC' started by HondaMan_2002, Jan 21, 2003.
  1. HondaMan_2002
    HondaMan_2002 Member
    I can't get any of my hoses off my engine. I have tried pulling on them but they wont budge. Is there an easier way to get them off?
    Also how do you get the sensor off that is bolted to the engine under the distributor on a 97 civic ex?
  2. nimblecivic
    nimblecivic Senior Member
    Southern IL, across the river from the Stl...
    Use a pair of pliers to twist the part of the hose that's on the fitting back and forth.....that should break it free from the fitting and make it easy to come off...
    Someone correct me if I'm wrong, but isn't that your vtec sensor?...if it's green it is....it should just unclip like the rest of them....
  3. HondaMan_2002
    No the plug is a black tube that is bolted into the engine directly under the disturber.
