swap
Discussion in 'HYBRID -> EG-EK / DC' started by colombian_jam, Jan 23, 2007.
  1. colombian_jam
    colombian_jam New Member
    miami
    well how you guys know i blow my LS engine, i have a EG. now i gat a B16A2 just motor but i wannted to know if i can use my wiring harnes or i will have to get a SI wiring harnes im not sure about that one so please help me ASAP also how can i wire the vtec....
    thanks
  2. random_hero
    random_hero New Member
    What year is you civic? If you have a '92 of any trim level, it's already wired for VTEC up to the engine harness itself. The answer is yes you can but it will be tight. I did that swap also, and used the DX engine harness. I was also able to run the VTEC wiring through the harness loom into the cannon plugs, thus avoiding a hackjob of hardwiring to the ECU. The only thing I hard wired was the knock sensor, which I couldn't find a pin out for. If you have any questions or didn't understand how I explained it just PM me.
  3. colombian_jam
    miami
    thank you so im pretty much i can use my wiring harness now my car is a eg 1994 my only question is to wire the VTEC is tooo hard
    or what
    thanks
  4. Domi31
    Domi31 Member
    Nor Cal
    I think you are asking if it is hard to wire-up the VTEC, no it is not.
    http://hondaswap.com/general-tech-articles/how-wire-vtec-40811/
    there is a artical on how to do it,
    what ECU will you be running, that is important becuase diffrent ECU's have diffrent pinouts for VTEC, VTEC oil pressure. here is the link for that
    http://hondaswap.com/reference-materials/ecu-pinouts-28667/ on this link it provides a pick of the pinpoints on the diffrent OBD ecus
    all of this has been taken from the Ref. section of hondaswap
  5. colombian_jam
    miami
    thank you guys i think i will make a soon that i finish i will tell how it goes
  6. colombian_jam
    miami
    i finally gat the old engine out and drop the B16A2 that shit is really fun and everything is working thank y ou guys for your help i will post p[ics of my car later on and i hope these doesnt get stolen like my other car .......
