cornfed85
wow man did you give the honda shop a jar of vasoline to bend you over when you took your car there?you should of asked around on here for someone experienced with a b series swap before you took it there...im sure if you had the motor...mounts...linkages...axles etc you could of got it done for alot cheaper
