Swaped buy
Discussion in 'Civic and CRX - EF' started by Linguo415, Mar 1, 2010.
  1. Linguo415
    Linguo415 New Member
    What up all. Im thinking about picking up a 90 CRX B18A. Not A1. I understand this is a JDM engine. I drove it and its all good. I would like to know what the red line is on the engine. I think the crx rpm guage only goes up to 5.5 or so. If anyone could shed some light on the subject i would greatly appreciate it. The crx forum has been no help so far. Also I would like to know if there is a good company online i can look up for engine rebuild parts. Thanks so much.
  2. EF4Life
    EF4Life New Member
    I'm pretty sure you've got a b18a1. Regardless, it redlines at 6500 RPM. Don't bother rebuilding, its not worth the money and you don't seem to have the know-how anyways.
  3. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    you probably have the obd0 version with 130hp and redline is 6600 i believe.
  4. ballerxforxsho
    ballerxforxsho New Member
    A Serie's Motor's = Garbage
    B-Seriesss
  5. BrutalB83
    Rochester Hills, MI
    What the hell are you talking about? He said the car has a B18 engine. No one said anything about the A-series...
  6. Linguo415
    Its not about not knowing how to rebuild it. I just dont have the space and tools for it.
  7. ballerxforxsho
    read before you comment
  8. BrutalB83
    Rochester Hills, MI
    How about you try to be more clear about what you're saying. All you said was the "A-series is garbage, go with the B-series". I guarantee you, 99% of people would read that comment and think you were referring to the A-series engines that came in some of the older Accords versus the B-series engines found in many newer Hondas (B16, B18B, B18C, etc.).
    If you had said, "The B18A is garbage, go with a B18B instead", that would have been much easier to understand. And, if you want to take this further, you're just plain wrong. The letters PRIOR TO the numbers are the engine series, and the letters AFTER the numbers are the model (i.e., a B18A is a B-series engine, A model), so really you're just plain wrong here.
    And no, the B18B isn't really that much better then the B18A. It flows a little better (which accounts for the 10 extra horses) and it's OBD1, but that's pretty much the only difference. Either of them are fine starting points for an engine build.
    Anything else you'd like to disagree with?
    EDIT: And once again, this thread is two months old...
  9. FLounder
    goddam brutal... im glad you are here to keep all these dumbasses in check.
