swaping a 2000 b18c1 into 92 civic dx
Discussion in 'HYBRID -> EG-EK / DC' started by tip, Jun 29, 2005.
  1. tip
    tip Senior Member
    Ennis Texas
    ok i have a 92 civic and i have just bought a 2000 b18c1 swap and it is still not here yet, but it is suppost to have "axes wire harness motor ecu tranny distributor starter alternator and ac compressor shift linkage and mounts ". So what will i need to get besides this and is there a book or guide that i could use to do this myself...? any help will help me greatly ...........thanks B)
  2. E_SolSi
    if its USDM all you need to do is wire up the secondaries
    if its JDM you will need to do a little more wiring
    all the info is in the reference section
  3. hondapop
    hondapop Junior Member
    Research threads and you will come up with most...just finished a b18c into 95cx hatch...a few things to find would be ecu pins, canon plug pins, check a/c bracket, look for radiator (or deal with hose size conversion), check, recheck, dbl check wiring connections...have fun
  4. jimboburgess
    jimboburgess Go fast, Go Cheap
    nyc
    not to take "business" away from this site, c speed racing has a pic by pic how-to on their site. I can't remember the site but google it.
  5. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    But other than the basics it isn't a real detail how to, still very good for a beginner to get the main idea.
