swaping brakes
Discussion in 'Wheels / Suspension / Tires / Brakes' started by tip, Nov 3, 2005.
  1. tip
    tip Senior Member
    Ennis Texas
    planning on completely swapping brakes on my 92-95 civic 4dr and was needing to know what exactly i will need besides the front and rears sold 2 Hmotorsonline. I will be buying these as soon as i know everything i will need. Thanks
    Here are the HMO listings.....
    SiR-G GSR Front Brake Setup. - Includes Rotors and Calipers.
    $75.00
    SiR-G GSR Rear Disc Conversion. - Includes Ebrake Cables.
    $175.00
  2. pissedoffsol
    rear fluid lines. the drum ones won't work.
    i'd also suggest getting a 91 ex sedan master cyl. its a $45 part and is 15/16" instead of 13/16
  3. E_SolSi
  4. jimboburgess
    jimboburgess Go fast, Go Cheap
    nyc
    what will the 91 ex sedan master cyl. fit on? Just eg's? does it have ABS?
  5. pissedoffsol
    abs is not a part of the master cyl anyway, but is is non abs.
    the reason it works great, is because it both fits the stock EG booster and the hardlines come out at the same spots.
    the gsr is also 15/16", but the hardlines will have to be bent, and its a pain in the ass.
    this one just bolts right in. 15 min job + bleeding
  6. tip
    tip Senior Member
    Ennis Texas
    well look does anyone know if the prop. valve come with the shit from HMO or will i need that as well....?
  7. 92dxhatch
    92dxhatch Senior Member
    nor*cal
    you need one as well bud.
  8. tip
    tip Senior Member
    Ennis Texas
    I know that i need it but my question is if any one knows if it comes with the swap from HMO or if it will have to be bought seperate....???????
  9. 92dxhatch
    nor*cal
    that was my point, sorry if i wasn't clear, you need to find one seperate from hmotorsonline, it doesn't come with one.
  10. tip
    tip Senior Member
    Ennis Texas
    oh ......ok thanks for the info. Should i hit up the local junk yard or pick up one of these new....? cost new if any one knows
  11. confusatron
    confusatron Senior Member
    Chicago area
    I've been stripping parts lately off a 94 Integra at the junkyard recently. The drivetrain is already gone and there aren't any emblems on it, how do I tell if its an LS or a GSR? Can I use the master cylinder and rear disc brakes from this car on my 93 hatch?
  12. 92dxhatch
    nor*cal
    yeah, an ls will work also.
  13. confusatron
    Chicago area
    I have a 93 Hatch, what car's rear fluid lines do I have to get?
  14. 92dxhatch
    nor*cal
    either an si or integra
  15. pissedoffsol
    look at the vin. look for something like DB2, DC2, DC1, etc in the first part of the vin: JHEM____
    can you sure.
    but its a pain in the ass.
    rear discs are no problem, but i'd advise against using the master.
    you will need to use the booster as well for the master to fit... plus gsr's are abs, so, you have to bend and move hard lines.
    its just so much easier to spend 45 bucks at autozone and buy the 91 civic ex sedan master. its the same size.
