derekburress
MadCityLude
I recently purchased a 1999 Type S H22a for my 1992 Prelude and need help. I need to know what special parts I am going to need to complete the swap. I only have the engine tranny and ecu with full harness. PLEASE HELP. Thank You B)
A couple things I am curious about, 1st and foremost I think my F series is using a cable clutch and the H22 uses a hydraulic how do I make this work. Second I do not have a full clip only engine, ECU, and trans., will I need the axles and other drive parts, or will my current attach easy. Also about header and exhaust I am planning to purchase new, but do I buy for the 1999 H22A type S or mix and match, or will I need a custom job done? Also I recently installed a TEIN SS suspension will I need to replace any of it do to the extra weight... I have read that the H22 will be heavier buy at least 60lbs is that true? Another concern is AC. Will the AC from my F series attach or not? Any help you can give is very appreciated.
Oh yea one more thing as far as the H22 is concerned what do you recommend doing to it before the install. It only has 36,000 on it and it runs strong but was in a serious wreck.
