Save the headaches and just swap in a zc, thats my recommendation. All you will have to do other than switching hubs and axles if you change the transmission is to wire for mpfi and change the ecu. I think that my d16a6 in my crx was much faster than my z6 wired obd0. I also think when I did it in my Civic that my crx si was faster. I just don't like the swap.
I have done the d16z6 swap twice. You will have to keep the bracket from your drivers side mount and put it on the new engine. I believe you will need a sensor off of the block of your original engine. (Its been a while since I did the swap). You can wire for 0bd0 or obd1. I prefer obd1 because the car runs better with the proper ecu, and you don't have to mickey mouse the distributor on. IF you stay obd0 you will have to modify the distributor.
Are you just doing the swap for more power or are you doing it because the block is shot? There are some people on Honda-tech who had stds and ran some low 15 second time slips without doing an engine swap. The engine responds well to the mpfi swap, and you will need to change the tranny out for a dx or si one.
