Swapped A D16z6, No Fuel Injector Pulse?
Sinner
Member
I did a swap and it was idling while about 30 minutes. To check for leaks. Anyway then I hooked up the throttle cable to and tried to adjust the tps sensor. Well when I hit the gas it would bog and finally it bogged and died. Now when I try to crank it Its not sending fuel. I know its has fuel pressure since I hook the fpr off and cranked which sprayed fuel everywhere. Then I tested the injectors buy manually turning them on and they worked. So i think I'm not getting a fuel injector pulse. Is there anyway to test for this? Anyone have any idea whats going on and how to fix it?
Nick
