swapped now no power. plz help
nicoleJDM
hey guys. car is a 94 del sol s automatic d15b7. i did the manual conversion and swapped in a d16z6 with a 99 ex tranny. the only thing not wired up is vtec. at first we had fuel but no crank probably bad starter. but then somone switched the starter and alternator connection in the fuse box without me knowing. then the next time i went to try to start the car, it lost all power. i was able to check for trouble codes before we lost power and all i had was code 19 for the auto tranny control valve. could i have fried the main relay. someone also told me to check the fusible link for alternator but would that cause it to lose all power. the main relay doest smell burnt but somthing in the car does smell burnt on the passenger side. thanks alot for ur help.
nicole
yea i have a p28. now i got it to crank but no spark and no fuel. fuel pump does not prime and main relay doesnt click. should i change the fuses.
