Ok, brand new here but not new to honda's.
I just got a 91 ef sedan with a b20z2 and S1 trans.
The S1 trans grinded and 5th wouldn't work at all.
I got a working YS1 trans with the car. I got a new clutch so the input shaft would fit right. I got it all done and back together today.
The issue(s)
Won't go into ANY gear with car running.
Will go in ALL gears with car off.
Cable adjustment is good.
I started the car in reverse and it would kind of go backwards and would have to be forced out of reverse.
Is the throw out bearing bad? Flywheel bearing? Trans? It could be a number of things looking to narrow it down
The issue(s)
