swappin out a 98 civic hx v-tech with a CVT tranny to a b16a2 v-tech with a manual . everything is changed over, shifter is in and i even found the rare p30 to go with it. heres the problem, my iac valve has no ground. its throwing the code for "iac valve system fault" and idles at like 200rpms. you hit the throttle to idle at around 1100 and it skips at you. a steady bop. could my computer be fried or what? did i miss something? the plug for the IAC was swapped froma 3-wire to a 2-wire cause the plugs were diferent from my stock harness to the new motor. please hurry...i need my baby back.
