swapping 2000 b16a2 in 88 crxdx what parts needed?
Discussion in 'HYBRID -> ED-EF / DA' started by g24jr, Aug 30, 2004.
  1. g24jr
    g24jr Member
    MCMINNVILLE, OR
    What ecu and wiring harness do i use for puting a usdm b16a2 from a 2000 civic si into a 1988 crx dx? will the ecu and wiring harness work from the 2000 si?please help
    thanks
  2. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    do you have the motor yet? If not get the b16 0bd 0 motor alot less work
  3. g24jr
    g24jr Member
    MCMINNVILLE, OR
    yes i already have the motor
  4. $k@m Art1$t
    $k@m Art1$t Junior Member
    Check out http://www.ardperformance.com for an OBD conversion harness. The ecu that came with your swap will work fine, and the conversion harness allows you to use the stock wiring harness that came with your car. However your going to need a cable to hydro conversion kit if you want to use the hydro tranny that came with your B16, or you could do it the other way and get a cable tranny from another B series. I'd recommend this swap over an OBD 0 swap simply because its way more reliable, and the extra work is worth it, especially since it's only 4 years old.
