salmaan_ali
Guys i've got a B16a(JDM Edt) with S1 tranny(manual) with a PR3(OBD0) ecu.
I have 87 Integra with D16a2(DOHC, Vacuum adv distributor, PG7 PreOBD)
after completing the swap i have to rewire it up myself to save money(as my buget is limited), most of the wires ffrom PG7 will go straight in PR3 (most sensors and Injtectors)..... i only have to wire Knocksensor, VTEC . I'm looking fwd to use the same/previous wiring harness.
but i dont know how to wire B16 OBD0 distributor , B16a dist has seven wires <span style="color:#CC0000">(which include two white wires on is thick one is thin and ONE another THICK BLACK/Yellow wire..... which i dont know where they will go ) </span>
also my vacuum adv distributor has external coil and a seperate crank angle sensor , im totally confused to wire which wiere where?
if anyone can guide me asap then i would be able to start my dohc plezz help
