I have a 00 civic ex, and i'm in the process of putting a 99 gsr dohc. The problem i'm having is the drivers side mount, i have to use the stock ex mount onto the gsr block, but the gsr mount has three bolts and the ex only has two, and the two wont line up with any two holes from the block. If anyone has done this swap b4, I would like some suggestions on what you did to make it work. Thanks
