Swapping A B18a1?
Discussion in 'HYBRID -> EG-EK / DC' started by RicanRacer253, Jan 18, 2003.
  1. RicanRacer253
    RicanRacer253 Junior Member
    Tacoma, Washington
    I have a 93 si hatch. I am thinking of getting a ls swap but i dont know what else to get for my motor. I am getting the motor and thats about it. What kinds of drive axles would i need, ecu, tranny? Motor mounts, wire harnesses??? Also i have a hydraulic clutch so what tranny would i have to get? Anyone out there wanna give me some info? Thanks guys
  2. SleEPeR_CRX
    SleEPeR_CRX Senior Member
    Vancouver B.C. canada
    dont get a b18a1 if u can, ull have to change it to obd1, its also cable clutch and ull have to change that. get a 94+++ b18b, u will just need to get axels engine tranny and ecu, and ur good to go. maybe shift linkage if u dont wanna modify ur stock 1.
  3. RicanRacer253
    Tacoma, Washington
    What times would i be running in my hatch with a b18b? whats the difference between the b18b and b18a?
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    No one can tell what times you'll be running in your car,w/ your skills,w/your mods,w/altitude,w/your...get the picture.The differences
    B18A1
    Displacement (cc): 1834
    Power (bhp@rpm): 130@6000
    Torque (ft/lbs@rpm): 121@5000
    Compression Ratio: 9.2:1
    Bore (mm): 81
    Stroke (mm): 89
    Cam Design: dohc
    VTEC?: no
    OBD: 0 or 1
    Year(s) Produced: 1990-1991
    In the following car(s): Acura Integra GS/RS/LS
    B18a1
    Power (bhp@rpm): 140@6300
    Torque (ft/lbs@rpm): 121@5200
    Bore (mm): 81
    Stroke (mm): 89
    Cam Design: dohc
    VTEC?: no
    OBD: 1
    Year(s) Produced: 1992-1993
    B18B1
    Power (bhp@rpm): 142@6300
    Torque (ft/lbs@rpm): 127@5200
    Bore (mm): 81
    Stroke (mm): 89
    Cam Design: dohc
    VTEC?: no
    OBD: 1
    Year(s) Produced: 1994-1995
    In the following car(s): Acura Integra GS/LS/RS/SE
    B18B1
    Bore (mm): 81
    Stroke (mm): 89
    Cam Design: dohc
    VTEC?: no
    OBD: 2
    Year(s) Produced: 1996-2000
  5. RicanRacer253
    Tacoma, Washington
    Well lets just say the better then average driver, im not the best shifter but can shift at the right times. Thanks for the info though.
  6. xj0hnx
    C.C.TX.
    Let's just say goto a track and do a few runs.I've heard people running 17 in Colorado and with the same set up 14 or 15 in Cali. Sorry there are too many variables but if you want a guess 15.??-16.??
  7. SleEPeR_CRX
    Dude my old B18a and I ran 14.56 with I/H/E clutch and lightened flywheel. i am no means the best driver, but as long as u get a good start without to much tire spin and a good light ull do fine. i believe i got a .658 or something close to that, i have the slip somewhere. I live in Vanouver BC Canada, so its a lot colder and closer to sea level than other areas.
  8. Integra1990
    Integra1990 Senior Member
    omaha nebraska
    ive seen a 93 hatch at the track run lik a 15.1 at best with a b18a or b im not sure which one, and i think he had sum mods, but he also had rims and that shit to weigh him down...
