Swapping flywheels
Discussion in 'HYBRID -> BA-BB /CA-CD' started by sniezek66, Sep 10, 2004.
  1. sniezek66
    sniezek66 Member
    Yes quick question. I found a motor on ebay put the h22a1 can off a standard tranny. The h23a1 i'm taking out of my prelude has an auto tranny. Question is can i swap flywheels?? Let me know
    Kurtis
  2. tab
    tab Super Moderator
    Aberdeen, Washington State
    I'm almost positive you can. I know of a person that swapped torque plates from a F22B1 to a H22A. The trannies bolt up the same too.
  3. topendms
    topendms Junior Member
    F22, F23, H22, H23 motors all use the same exactl clutch and flywheel. Their transmissions also bolt up to each other ..
    If your auto, the tranny mount is different on the manual and will need to be drilled or welded in.
