Swapping heads : d15b7 head to d16z6
Discussion in 'General Tech and Maintenance' started by CRXSI91, Nov 30, 2004.
  1. CRXSI91
    CRXSI91 Senior Member
    ok...i have the d16z6head...and i want to put it on my b7 block..i have a 91 crx si....its already wired up for Vtec...but from what ive been told,i will need a "si or Ex" ecu from that year (92-95 vtec ecu)...but then ive also been told i wont need it...now im prepared to buy that ecu on thursday..but im trying to figure out if i can put the head on without it...can someone help me out...right now im running the dx motor off of my stock si ecu.
    thanks.
  2. THEUSED
    THEUSED Junior Member
    CRX SI came with a D16A6 not a D15b7
    Im not sure if you swapped that block in or what.
    Anyways you have to have either a vtec or nonvtec OBD1 ecu
    NON vtec ecu=vtec on a switch
    Having a vtec ecu from 92-92 EX,SI,VX will have vtec activate when it reaches the required rpm
    Im not sure what you mean its already wired for vtec
  3. phunky.buddha
    Dallas / Fort Worth, TX
    If you're going to add a VTEC ECU, you'll need to convert the car to OBD1. If you don't want to use a VTEC ECU, you can add a piggyback VTEC controller like the Apex'i VAFC.
