Swapping Hub From 4-lug To 5
Discussion in 'Wheels / Suspension / Tires / Brakes' started by Drock42, Jan 13, 2003.
  1. Drock42
    Drock42 Senior Member
    Alamogordo, New Mexico
    How tough would it be to swap a hub from 4-lug to 5? The reason would be to stick the '03 Accord V6 wheels onto my '97 Accord lx.
  2. chris
    chris Senior Member
    nihon
    i am not sure on the specifics relating to the diameter of the two different hubs that u are going to use (accord), are they the same size or not? just speaking from integra/civic hubs which are different sizes, it is a decent amount of work.@@need to get the knuckles machined to the proper bore then press the 5 lug bearings into place. be careful about removing and installing the bearings, you dont want to have to buy new ones, pretty expensive. hth's
