Swapping OBD-1 B18A into EG
Discussion in 'HYBRID -> EG-EK / DC' started by Sinisterfuzzy, May 4, 2007.
  1. Sinisterfuzzy
    Sinisterfuzzy New Member
    I heard that doing an obd-1 b18a swap into an eg isn't as bad as the obd-0 swap. So, I have a complete 1992 Integra LS.and a 1992 Civic CX. So what are all the parts i'm gunna need, i searched all over and could only find the obd-0 b18a swap info. So, what do i need to gather? can i junkyard parts? I'm sorta trying to just get this running for now, so whats a cheaper way to go?
  2. Sinisterfuzzy
    bump
  3. momo_it
    momo_it New Member
    im in the middle of doing the same thing, if you have the cable tranny, you gonna need to drop it and get your self 94-00 tranny and axles, your also gonna need the rear mount off an integra, shift linkage, and i think thats it.. ecu maybe..
  4. Dark93DX
    Dark93DX New Member
    B.C.
    The EG civic is OBD1 so there is no issue if your engine is OBD1 also. should be pretty much plug and play, assuming you got shiftlikage, axles etc.
