Swapping SiRII into 96 Ek... getting mixed answers...
Discussion in 'HYBRID -> EG-EK / DC' started by NARKOSIS, Oct 23, 2006.
  1. NARKOSIS
    NARKOSIS New Member
    Im ordering the complete swap from hmotorsonline tomorrow morning including the necessary mounts, OBDII -> OBDI conversion harness, water pump, oil pump, timing belt, radiator hoses, etc. My only concern is with the ECU. If they are supplying me the conversion harness, is everything PnP??
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    reprase what your asking please
  3. NARKOSIS
    NARKOSIS New Member
    not exactly sure how to rephrase it? :mellow:
    buying a b16A (SiR-II)
    want to put it into a 96 hatch
    no emissions to worry about in florida
    its being shipped with P30 ECU and OBD-II -> OBD-I conversion harness
    When it comes to the conversion harness is everything plug and play? I hear horror stories about the wiring here and on honda-tech. But is all that irrelevant when I get the conversion harness?
    yes im new to this, my original motor blew up, dont feel like fixing it and want a better performing motor/tranny. Point and laugh at the newb if you'd like. But I just need a clear answer to this seeing as how Im purchasing the swap tomorrow morning.
  4. AHHVTEC
    Alabama
    yes its plug and play just got to run a few wires for vtec
  5. NARKOSIS
    NARKOSIS New Member
    great, thanks for the answer man, much appreciated
  6. honda big block
    honda big block New Member
    hey bro it seems like alota work to me... if your new to wrenchin on honda's that wire harness stuff is no joke make you get one of haynes books for b-series motors. good luck man
  7. 97ekhb
    97ekhb New Member
    new question
    i the company you are ordering your swap from is giving you the complete swap. then why would you have to get a wiring harness. i thought the only thing different from obd1 to obd2 was the ecu and engine.
  8. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Because Japanese cars engine harness are backwards, hence other than plugs useless.
    Talk tot hem and see if they can score you a 96+ SiR swap, then it would be a lot more plug and play.
  9. NARKOSIS
    NARKOSIS New Member
    yeah, thats what i ended up getting. steve at hmotors explained it all and they had two 96+ SiR swaps. costed me a bit more money but will save a lot of hassle. the obd1 swap was 2600 to my door whereas the obd2 swap was 2975. should have it by next weekend.
  10. xj0hnx
    C.C.TX.
    Awesome, glad to hear it :)
  11. NARKOSIS
    NARKOSIS New Member
    yep, im pretty stoked. My buddy whose doing the install has an rsx type-s, intake, exhaust, ecu mod and wants to see what a gutted ek with a stock b16 will do ;)
  12. NARKOSIS
    NARKOSIS New Member
    sweet, Steve at hmotors threw in the LSD tranny and Jasmine (sp?) headers for $200. Happy about that one :thumbsup:
  13. NARKOSIS
    NARKOSIS New Member
    does anyone have any input on this header? I cant seem to find anything about it :confused:
