swapping tranny auto to manual 97 cx h/b
Discussion in 'Civic and del Sol - EG and EK' started by 97_cx, Oct 4, 2006.
  1. 97_cx
    97_cx New Member
    hi i wanna swap a auto tranny to a manual tranny i need some help can anytone help me with this thx.
  2. igotnothin
    igotnothin New Member
    harford co MD
  3. turbo sol
    turbo sol I need some ligaments!!!
    laurel, montucky (ten minutes out of billings)
    hey i'm doing the same to my del sol. if you're gonna do the swap you'll need the following:
    master and slave cylinder
    clutch reservoir
    hydro lines
    pedal set
    new mounts
    shift linkage
    shifter bushings
    manual console
    shift arm, boot, and knob
    manual starter
    clutch, pressure plate, and flywheel
    obviously the trans
    new ecu or conversion(auto to manual. try phearable.net)
    throttle cable
    that should be everything you need to get the deed done!
