ef9civicgen4
i was wondering if 93 Integra LS Special sway bars will fit on an 89 Civic DX hb. im pretty sure the rear will fit, there are already holes drilled but there is metal sealing one of the hole. so, will the front sway bar fit, and would it be okay to drill out the blocked hole, or am i going to drill a hole into the fuel tank? if they do fit will it help the handling?
