Switching sensors
RIT Civic
Ok here is the thing. I have a b16 engine obd0 which i am planning on putting in my 92 civic vx....i was thinking since i have a b series obd1 vtec dizzy already would it be ok if i just take all of my obd1 sensors from my sohc vtec vx engine and put them on the b16 so that i won't have to find a wire harness for the engine?...
In other words i want to convert the sensors from obd0 to 1 to avoid having to look for and swapping out a obd0 harness
you need to run the dizzy, alt, and injectors that match your ecu. consult the swap section. theres is an article on this in the 5th gen swap section.
