T-belt
Discussion in 'General Tech and Maintenance' started by highperboi, Oct 14, 2003.
  1. highperboi
    highperboi Senior Member
    Alameda, California
    How tight should my timing belt be? i think its loose cuz it moves left and right bout half a inch each way or alittle more. i got a b18c1. also how do i tigtin it? its that 14mm bolt under the mount right?? i tried to tighten it but it wont budge....
    :unsure:
  2. CRX_B16B
    CRX_B16B Senior Member
    get a manual it'll tell you how to do that
  3. B16
    B16 Super Moderator VIP
    yay area, CA
    you loosen it, then tighten it. it needs to be loosened for the spring to apply the tension, then you tighten it to hold it in place.
  4. arpee79
    arpee79 Senior Member
    OK this is what i do, you need to somehow make all the play in the timing belt be on the right side towards the alternator then loosen the the tensioner bolt and the play will magicaly disapear and then tighten the tensioner bolt again.
    NOTE: be sure to align all the marking on the cams and the crank pulley CRUCIAL.
    GOOD LUCK
  5. B16
    yay area, CA
    you dont' need to worry about timing when tensioning the belt, not like its going to slip off the teeth. but yes, you want your slack on the side that is towards the rear of the car.
  6. arpee79
    yeah i meant be sure they are aligned
  7. highperboi
    Alameda, California
    could i crank it by hand?
  8. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    I believe that if you are able to twist the belt half way then it should be tightened some so that it's a little more tough to twist it half way...if that made any sense?
