S steade90 New Member Apr 2, 2007 #1 Hi just wondering which would be better on a stock B16a2 engine. im only going to run about 6-8psi probably a rev hard kit (from turbo-kits.com) but im not sure if its better to have a T3 turbo or T3/T4. Which will spool faster?
Turbo&Auto Nick Go FAST!! Apr 2, 2007 #2 Should be the same spool time if you have a T3 with a .48 and a T3/T4 with a .48. I would get the T3/T4.
J jimboburgess Go fast, Go Cheap Apr 2, 2007 #3 bigger means more power and therefore is better. t3/t4 for you.
