T3 Turbos -- What Is The Swing Valve Assembly
Discussion in 'Forced Induction' started by tripple sik, Feb 21, 2003.
  1. tripple sik
    tripple sik Member
    On the T3 i see what i found to be called the swing valve assembly. What is it and what does it do and where does the hose that runs out of it go? Also, why is it not on The T3/T4 hybrids? I'm planning on turbocharging and would appreciate the help.
    This is to sohcem... the ITR is too costly and i want more power potential bro... thnx for the help though...
  2. cws13
    cws13 Senior Member
    Athens,GA
    It's a type of wastegate and if you get a turbo that doesn't use one...there are different kinds. i haven't looked but I'm sure they have an article breaking down the types somewhere around here-or you could ask the manufacturer.
  3. tripple sik
    tripple sik Member
